It is currently Wed Jul 17, 2024 11:38 pm
 Post subject: A Fine Fine Amplifier
PostPosted: Thu Mar 05, 2009 5:08 pm
Indeed, I have spent a couple of days with V5 (or was that the M5 multitronic unit). Anyway, I like it a lot because.
1) It is fast. The notes (especially the midrange stuff) seem to come out of the amp just slightly before you play them. This is the same feeling I get from the clean channel of some Two Rocks. It can be frightening and is always revealing. This is evidenced by my flub in the attached clip. It couldn't be more out there and in your face. Careful kids lest your ass be exposed like your wearing a pair of Princes chaps!
2) The overdrive is freakin sweet. When I engage the overdrive I can get a feedback even when the tone is fairly clean. (once again see clip below). This happens at fairly low volume too.
3) Distortion - I cranked everything with a Les Paul and immediate heard the metal gods commanding me to Thrash!!! (that's right John). This will be my next clip cuz this sound is WAY beyond anything I would think of for this kind of amp.
4) See you at 12! - The amp sounds great with everything at 12 o'clock. You don't have to go too far from there for many tonal variants. Scoop the mids for a clean fender like tone (sorry got a fender for that) and crank the treble and presence for some TriWatt spank.
5) Tone controls are usable - and they actually do something without farting out or piercing your ears or anything nasty like that. No Bass on zero with this amp.
6) Clean and Dirty and the Creamy in-between. Clean sound is unique. Full bore distortion is absolutely psychotic but that area where the amp just starts to break up and get meaty is the place I like the best. I have the best time of it with the master pretty much cranked and the volume and gain turned up as much as I need to to get the guitar into that happy place. This is a different place with different guitars. Here are the settings I used to get to (and maybe just a little past) this place with the strat.
'62 Reissue Strat - Bright Input - Volume 12oclock - Overdrive Out 2 - Bass 12 - Treble 3 - Mid 2 Presence 2. Trinity 2x12 with TT alnicos
7) This thing sounds great with alnico's but it also sounded great with G12-65's in a 4x12 slant cab (really good). Fantastic bottom end clarity.
I have modified my rig for the next gig and did a quick test. It was very promising. I was using a two rock and TC2290 with some effects in the TC's loop (which was a great tone at the last rehursal). Tonight I will switch to stomp boxes on the floor straight into the TW set to the inbetweeny spot I like so much. Pedal board is as follows
Volume pedal > tuner > BB Preamp > Boss Dimention > MXR Flanger > Sparkle Drive > Keeley Compressor > Ibanez DE7 Echo > Verbzilla.
Early testing sounded pretty good with no spikeyness or skanky tones right from the start. This means I can have maximum play with how I set the pedals without getting into the tinny skank zone that cuts in an ear peircing way and not a happy way.
Coco will post the link to the clip later. It is recorded quick and dry. I stuck a 57 about 4 inches in front of the amp and hit the record button on pro tools. No tweaking no nothing. I will do a little more setup for the dirty tone. I went flat into and out of protools and mastered in Audition. Once again, no comp, no eq, no nothing. (yes it was difficult).
We'll see how it sounds in the big room tonight.
Cheers
Larry
Clip: Take1
Guitologist at Large
"How does that feel?"
PostPosted: Thu Mar 05, 2009 7:54 pm
:rol You really have such a way with words! :lol:
lbethune wrote:
Clip: Take1
I think I just heard my favourite Hiwatt tone there! :D :D
PostPosted: Thu Mar 05, 2009 10:51 pm
now that was sweet!
AJC
PostPosted: Thu Mar 05, 2009 11:57 pm
Spot the TRIWATT!
The TRIWATT handled this setting in a good size room at Half Vol, Half Master 1/2 - 3/4 OD. Rest of the settings were pretty well in the middle as you can see in the picture below. I was really impressed at how well it hung in there. On slide guitar it was nice and clean, at times very country. But on Sufragette City, 3/4 OD it was rockin. Larry likes the OD on. Fantastic sustain. This amp is very articulate and fast - I could hear the pick at times. I am very happy with it.
PostPosted: Fri Mar 06, 2009 9:29 am
Well, I asked for a Gilmour-ish clip & that one delivers. Awesome...
And then he gigs with the thing! Following in the footsteps of Mr. Reeves...prototypes used by gigging musicians! Nice to hear it held up well (like there was any doubt). It must have brought a big smile to Stephen & Phil's faces!
I've always felt that if an amp sounds good with all the knobs at about noon the designer(s) did their homework & you have a special amp on your hands. You have a base tone that you can tweak. My Laney is like that too. The difference being the Laney does one trick well (incredibly well in fact) while it appears the Triwatt has plenty of tricks in it's bag.
PostPosted: Fri Mar 06, 2009 10:01 am
Notice he's not using the linked input just the normal. ??
Stew
PostPosted: Fri Mar 06, 2009 10:32 am
Stew
Yes, I let my ears do the talking. (WTF?) I guess my mouth has been doing most of the listening? What I mean is I just plugged in to where I got happy tone. Didn't care what knobs went where or who was plugged into what. I got the best feel from the amp for my playing style by plugging into the Bright input along.
Mind you this lack of front end gain is heavily mitigated by the fact that I have been running the amp EXCLUSIVLY in overdrive mode. This has been true even when I am seeking a clean sound.
PostPosted: Fri Mar 06, 2009 1:16 pm
You better bet it did. :D Especially given that this is a prototype that's been hacked and modded umpteen times.
It's actually the Bright input, as Larry says here.
I'm pleased to see the Bright input is so usable.
lbethune wrote:
I have been running the amp EXCLUSIVELY in overdrive mode. This has been true even when I am seeking a clean sound.
I found you can get real great sparkly clean tones in the overdrive mode.
BTW what kind of Marshall cab are you using there? It looks like a bass amp cab... :shock:
PostPosted: Fri Mar 06, 2009 2:07 pm
The cab was a standard issue Marshall 412 with G12-75s. Even so, the sound sparkled from the back of the room and stood out. I guess it was the bright input that helped there.
On Suffragette city, Larry used the linked input and more OD to get a great sound that was very close to Bowies 'Spiders' band on that tune.
PostPosted: Fri Mar 06, 2009 3:27 pm
Will I need to pull my V30s and install the G12T-75s I have sitting around, in my 2x12" Cabinet? I know Hiwatt currently uses the G12T-75 in their "cheap" cabinets.
ROB
PostPosted: Fri Mar 06, 2009 7:46 pm
why not one of each 8)
PostPosted: Sat Mar 07, 2009 7:34 am
Not so sure about that. These were just the studio cabs. I'm sure Larry has other opinions on the speakers, as does Brent.
PostPosted: Sat Mar 07, 2009 7:38 am
Last night I fitted the Partridge clone OT on to TRIWATT. I'm hoping to get this into Larry's hands this week-end for another round of tone testing.
I made no other changes but I really wanted to hear how this OT sounded when compared to the 'EZ' version Partridge design OT we've been using.
PostPosted: Sun Mar 08, 2009 10:00 am
I took the TRIWATT with the 'Clone' OT to Lawrence. After playing it for a while, we both thought it was brighter or maybe it had lost a little girth/bass and it distorted sooner. For me, it was a lot like the effect of switching in the .047uf cap back into v3 circuit. He also found he was dialing more on the controls to get to where he was previously with the EZ OT. Lawrence was surprised to learn he was playing the Clone and not the EZ version.
Bottm line - we both liked the EZ more.
PostPosted: Sun Mar 08, 2009 10:40 am
Interesting :!:
Sounds like the EZ is the way to go :D
Next question is:
When do you try the KT-66's :D :D :D
Interested in how those sound :P
PostPosted: Sun Mar 08, 2009 11:36 am
I know Phil has tried them but we haven't studied them. There is a short 3 day window between today and Lawrence's next band practice.
PostPosted: Sun Mar 08, 2009 2:39 pm
Sounds good, looking forward to the updates :D :D :D
PostPosted: Sat Dec 04, 2010 12:46 pm
Cheers
Larry
Clip: Take1
 Post subject: Re: TRIWATT Take5
PostPosted: Mon Dec 06, 2010 2:06 am
Sounds like another very satisfied customer! Pretty much echoes (no Pink Floyd pun intended) the review I posted on Harmony Central. It's still my main amp, and I really don't see that changing any time soon. :)
