It is currently Fri Apr 18, 2025 4:57 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: Tweed Deluxe Kit
PostPosted: Mon Oct 08, 2007 5:30 pm
We are making our Tweed 5E3 Deluxe amp available as a kit. The price is $445 USD Everything is included except speaker and cabinet.
We are now shipping the Tweed kit with a significantly overrated power transformer so it runs cooler and the Output Transformer has BOTH 8 AND 4 ohm taps so you can now safely connect up an 8 ohm extension cabinet.
Shipping not included. $40 shipping in North America. Canadian Customers pay applicable sales tax.
The chrome chassis is made in Canada using our artwork. We eliminated the ground switch and labeled it a Standby switch. The chassis is tapped to fit the tube mounting screws and jack mounting holes are punched to fit the supplied insulating shoulder washers. Our grounding scheme is proven to be better and quieter than the original and other designs. In addition, we designed a proper way to mount the eyelet board and had holes punched in the chassis to suit.
Transformers are key to the sound of an amp. Ours are made by Heyboer in the USA exclusively for Trinity Amps using our design specifications. Like all Trinity transformers, these are heavy duty, well built and intended to last a life-time - unlike some lower cost products. The Power Transformer delivers 400 VDC B+ with Sovtek 5Y3 or 360 VDC B+ with JJ in this application. The 6.3 V is center tapped so no awkward grounding resistors are required - another improvement. The output transformer has heavier guage windings and is based on the Fender #108 design now with 4 AND 8 ohm taps..
Features:
* Chromed Welded Steel Chassis with White Lettering - 14.5W X 4.125D X 2.625H
* Switchcraft Jacks
* Carling Switches
* Belton tube sockets with tube retainers or shields
* Carbon Composition resistors
* Type 715P Orange Drop capacitors
* 1/8" GP03 eyelet board
* 22 guage hook-up wire. Pre-twisted 20 guage heater wire.
* JJ 6V6, 12AX7, EH 12AY7, Sovtek or JJ 5Y3 Complete Tube set
* Heyboer Custom Transformers with dual Voltage 117/234 @ 60/50
* 60 + pages of Full Documentation.
* Larege format 11" X 17" Layout & Schematic
Note: Most companies charge extra for Switchcraft Jacks, Carling Switches, Carbon Comp resistors, Export voltages and provide thinner eyelet board material. And most provide minimal or no documentation or support. We invite you to compare products.
It's built old school. Sounds and looks vintage Deluxe!
Buy your Kit with confidence!
Review Here: Guitars Canada
PostPosted: Wed Nov 21, 2007 3:23 pm
The Tweed Deluxe Kit will include our Custom Heyboer Transformer Set. Now available separately and made in USA.
SPECS
Trinity Tweed Deluxe Custom Power Transformer
> > 117/234 VAC mains
> > nominal 360-0-360 no load 350 V @ 150 ma - Red-Red/Yellow-Red
> > nominal 5 volt 3A - Yellow-Yellow
> > nominal 6.3 VCT 3A - Green/Green-Yellow/Green
> > black bell cover on top
> > black bell cover on bottom with hole on narrow end
> > delivers 400 V DC B+ with new 5Y3 tube; less with NOS 5Y3s or JJ.
Trinity Tweed Deluxe Custom-108 Output Transformer
now with 8 AND 4 ohm output
> > Same design & construction as original including old school steel.
> > 32.06:1 pri/sec ratio, 8 ohms.
> > M-27 steel.
> > leads: 3 in 3 out. Black/Yellow (8 ohm)/Green (4 ohm) sec; Brown, Blue with Red CT pri.
> > Trinity logo on OT wrapper.
Trinity Tweed Custom Transformer Set - $165 USD
Trinity Tweed Custom Power Transformer - $110 USD
Trinity Tweed Custom 108 4, 8 ohm Output Transformer - $90 USD
 Post subject: Deluxe kit
PostPosted: Sat Nov 24, 2007 9:30 pm
Stephen; is this chassis for a combo and not a head configuration? I'm hoping you changed your mind since the last time we talked.
Jim
PostPosted: Sat Nov 24, 2007 9:37 pm
Combo. Still.
But you can build a head cab around this chassis. A cab would need to be about 8-1/2" deep in total I think. I investigated this with another vendor & found out they used a combo chassis for heads.
PostPosted: Sat Nov 24, 2007 10:06 pm
Trinity Deluxe Chassis - Chrome
Rear View
PostPosted: Thu Jan 10, 2008 10:44 pm
by Heyboer - with 6.3 VAC Center Tap!
Trinity Tweed Deluxe Custom Power Transformer - Note the end 'O' hole!
Trinity Tweed Deluxe Custom - 108 Output Transformer
PostPosted: Thu Jan 10, 2008 10:53 pm
Trinity Tweed Deluxe Built Board - 500 Volt Filter Caps!! Orange Drops shown
PostPosted: Mon Jan 14, 2008 8:21 pm
Offer extended thru February.
PostPosted: Sat Apr 19, 2008 9:43 am
Just curious!
Are the transformers interleaved or straight like the original Deluxe? :?
PostPosted: Sun Apr 20, 2008 1:30 pm
jac wrote:
Just curious!
The output transformers are straight - like the original. Like a choke! More expensive, more original, more better!
PostPosted: Sat Nov 15, 2008 1:09 pm
Heyboer Custom Transformers now come with 120/240 Voltage and beefed up 120 ma secondary.
Same price to our customers too!! :D
PostPosted: Sat Nov 15, 2008 4:32 pm
Are you asking 400 Canadian or U.S. Thanks
PostPosted: Sat Nov 15, 2008 8:01 pm
USD. Not so long ago it didn't matter. :( Some Canucks took advantage of that! :wink:
PostPosted: Sun Nov 30, 2008 9:26 pm
Now shipping our kits with 20 guage solid hook-up wire!
 Post subject: Re: Tweed Deluxe Kit
PostPosted: Mon May 03, 2010 8:06 pm
Added Link to Guitars Canada review.
PostPosted: Mon May 03, 2010 9:09 pm
Coco, the link is broken. It has an extra character at the end "="
It's listed as:
http://www.guitarscanada.com/content/38 ... -kit.html=
Should be:
http://www.guitarscanada.com/content/38 ... e-kit.html
Excellent review. I'm enjoying my Trinity Deluxe! :D
PostPosted: Tue May 04, 2010 7:07 am
Fixed. Thanks for pointing it out!
PostPosted: Sat Oct 02, 2010 8:23 pm
Great review :happydance: :happydance: :happydance:
Curious as to wha kind of Orangs drops your using ?????? :damntech: :damntech:
PostPosted: Sat Oct 02, 2010 10:29 pm
Look like 715.
PostPosted: Mon Oct 04, 2010 4:45 pm
Yes, Type 715P Orange Drop Capacitors. Polypropylene film. Radial Leads. +/-5% tolerance. Rated for 85° C Operation . The 716P have copper leads but are also Polypropylene film.
