It is currently Sat Apr 05, 2025 3:17 am
PostPosted: Fri Sep 26, 2014 6:50 am
Hi all,
I'm new enough to this game, I've made some pedals and repaired/modded some amps but I really want to step it up and build a lightning clone, however I'm struggling to find quality suitable transformers locally in Ireland (240v here).
Hammond are readily available, but I'm not 100% sure which ones would be best.
This is what I'm considering:
- OT: 1650E (15W, 8k primary, 4/8/16 ohm secondaries - presumably just run an 8ohm speaker on the 8ohm secondary?)
- PT: 290NX (290v not 285v - big deal?)
- Choke: 158M (100ma, 195ohm) or 159P (125ma, 155ohm)
Anyone any thoughts?
PostPosted: Fri Sep 26, 2014 11:17 pm
All those would work. But I would not recommend the Hammond Output transformer. Just doesn't cut it IMO.
PostPosted: Sat Sep 27, 2014 3:31 am
Thanks Stephen, anything you can recommend that might be available in the UK?
PostPosted: Sat Sep 27, 2014 8:01 am
Try the Amp Maker . http://www.ampmaker.com/store/
