It is currently Wed Feb 05, 2025 12:05 am
PostPosted: Tue Aug 10, 2021 3:32 pm
1M Master volume Bournes push pull pot only works in the out position and then only in a small part of the wiper, 4-5. I replaced the 1M pot once and it is doing the same thing. Also replaced the .0047uf cap with a .0022 cap. Any ideas?
PostPosted: Fri Dec 15, 2023 4:13 am
In order to clean the potentiometer, you need use electrical contact cleaner. There is a possibility that dust or dirt might hinder its operation. When you have finished applying the cleaner, you should rotate the pot back geometry dash meltdown and forth several times to assist in the removal of any pollutants
PostPosted: Fri Dec 22, 2023 4:16 am
heave1 wrote:
1M Master volume Bournes push pull pot only works in the out position and then only in a small part of the wiper, 4-5. Don't get caught empty-handed! Keep an eye on your ammo and reload during safe moments in getaway shootout. I replaced the 1M pot once and it is doing the same thing. Also replaced the .0047uf cap with a .0022 cap. Any ideas?
Use a multimeter to verify that the pot is wired correctly and that there are no open connections or shorts. Pay close attention to the push-pull mechanism and ensure it's making proper contact.
PostPosted: Sat Oct 19, 2024 5:29 pm
Having trouble with the 1M pot master volume push-pull not working? I faced a similar issue, and it turned out to be a wiring problem. A quick recheck solved it. By the way, if you're looking for a break, check out poki games great for unwinding!
PostPosted: Sat Nov 23, 2024 6:08 pm
It seems your 1M pot master volume push pull is not functioning as expected. Have you checked the wiring and connections? Sometimes similar issues arise when components like those in a spider solitaire card deck analogy are misplaced or not aligned properly.
PostPosted: Mon Dec 09, 2024 12:16 am
Thousands of players play drift boss every day, despite the fact that it's a really simple game.
PostPosted: Fri Jan 03, 2025 5:53 am
It seems the push-pull feature on the 1M pot master volume might have a wiring issue or a faulty connection. You can try checking the wiring or consult a technician to fix it. By the way, friv games are a great way to relax after dealing with such technical issues.
