It is currently Sat May 31, 2025 7:04 pm
PostPosted: Sun Dec 06, 2020 12:27 am
Hi guys so I just installed the vrm and dumbleator in my tc15 and everything sounds great but I noticed that there is still a very audible signal flowing through channel one while the standby switch is engaged. Is this normal? I didnt notice it before but I can't promise the signal wasn't there before the vrm.
Am I supposed to remove the standby switch resistor maybe?
Thanks in advance,
James
PostPosted: Tue May 11, 2021 12:42 am
Same issue here - have VRM (but not Dumbleator). Did you resolve the problem?
PostPosted: Wed May 12, 2021 12:57 am
After some reading it seems that having a 47K ohm 3W resistor across the standby switch is good for the valves when the amp is left in standby for an extended period (this is the simple explanation). And I noticed in the VRM install manual it is not shown. So I've now removed mine - Stephen, please chime in if I've missed something!
PostPosted: Mon May 27, 2024 4:49 am
It sounds like there might be a leakage issue with the standby switch or another component in your TC15 after installing the VRM and Dumbleator. It's not typical for audible signals to pass through when the standby is engaged. You might not need to remove the standby switch resistor, but checking the installation and connections of the Drift Hunters and VRM.
PostPosted: Thu Jul 18, 2024 10:47 am
A standby switch typically cuts the high voltage to the tubes in a tube amplifier while keeping the filaments heated. This prevents the amplifier from producing sound, as the tubes are not operating at full power. Therefore, when the standby switch is engaged, it should not allow a signal from any channel, including channel 1. fireboy and watergirl
PostPosted: Fri Jul 19, 2024 3:19 am
Some signals may cross channels and cause interference to the audio channel. This can happen if the devices are not placed properly or there is a problem with the way they interact with each other. geometry dash
PostPosted: Wed Aug 07, 2024 1:16 am
From my research, it appears that placing a 47K ohm 3W resistor across the standby switch benefits the valves when the amp remains in standby for long periods. However, I noticed this isn't mentioned in the VRM installation manual. Consequently, I've decided to remove mine. Stephen, feel free to correct me if I’m overlooking something! Check also the website for the ultimate battle royal experience. Download the game https://ffadvancedserver.com/, explore immersive gameplay, and join millions worldwide in intense, fast-paced action. Survive, be the last one standing, and embrace the excitement of Free Fire!
PostPosted: Wed Aug 07, 2024 1:17 am
PostPosted: Tue Nov 26, 2024 7:48 pm
Great posts guys thanks! I enjoyed reading this
PostPosted: Thu Mar 13, 2025 5:10 am
Some amplifiers have a standby design that only cuts off the high voltage (B+), but if there is another signal path Suika game still running (e.g. feedback or improper grounding), the signal can still leak through.
PostPosted: Thu Apr 17, 2025 8:35 am
Hey! That’s a good question. It’s not unusual to hear a bit of signal bleed with the standby engaged, especially after mods like the VRM and Dumbleator (Checkout). You might want to double-check the wiring and grounding. As for the standby resistor, I wouldn’t remove it without confirming with a proper schematic or someone familiar with that specific setup.
PostPosted: Sat May 17, 2025 5:55 am
There may have been a misconnection or a faulty component during Escape Road James' installation of the new modules, creating an unwanted signal path bypassing the standby switch.
PostPosted: Tue May 20, 2025 12:17 am
Hey James, glad to hear the VRM and dumbleator are working well! That signal bleed on standby can be tricky. It might be normal, but let's troubleshoot. Did you ever play Papa's Pizzeria ? Remember how you had to check everything was just right before serving? Same idea here – double-check your connections and grounding. The standby resistor might be the culprit, but I'd research your specific TC15 model first. Good luck!
