It is currently Sun Dec 14, 2025 12:43 am
Post new topic Reply to topic  [ 89 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Thu Apr 05, 2007 7:21 pm
New TC-15 Strat & SG clips posted at:
viewtopic.php?t=834&highlight=
PostPosted: Tue Apr 10, 2007 4:37 pm
kinda new aruond here - i already buit a 2 channel 18watt tmb with some help from the 18watt forum gents and this new project here sounds very interesting
one question from an ignorant newb - how is this amp diff than a dc30 on the 1/2power setting?
PostPosted: Tue Apr 10, 2007 8:35 pm
kinda new aruond here - i already buit a 2 channel 18watt tmb with some help from the 18watt forum gents and this new project here sounds very interesting.
Newbs welcome here!
Slightly different power supply (same/close B+) & our custom OT; 1 less cap in the Tone contour; 5AR4 rectifier only; no Loops, no phase reverse switch; no master pull off switch and uses older EF86 biasing. It uses an eyelt board for build neatness.
Who needs 30W anyway? :D
PostPosted: Wed Apr 11, 2007 6:45 pm
I sure as heck don't... My church sanctuary is so live I have to keep the master on 1...
http://www.languagepool.net/images/band760.jpg
PostPosted: Wed Apr 11, 2007 8:43 pm
Yes, it's amazing to find how many people think they need power. You dont actually. Adding a second speaker is like doubling the power because it's add 3db to the level.
In a hard surfaced area like a church, a little goes a long-long way.
PostPosted: Sun Apr 15, 2007 10:00 am
How about an explanation concerning this impedence mismatch with the OT and speakers. Is this something common with the vox sound. Just curious since I now own Number "2" :D
Thanks, Jac
PostPosted: Sun Apr 15, 2007 12:59 pm
There's always been a lot of discussion on this. Here's a link to one of them..there's more. The mimatch give you a charateristic sound with a bit of an edge to it. You can simulate this if you want by mismaticing your impedance setting to your speakers.
viewtopic.php?t=38&highlight=mismatch
PostPosted: Sun Apr 15, 2007 2:34 pm
Thanks for the reply.
Read all, still want to know what advantage hooking up the 8k instead of the 5k difference is. I like Brian May, I think this amp can pull off his sound. Or very close. Without the deacy :D
The clips posted were awesome. So I'm curious which direction to go.
It's funny, I wanted an 18watt, But I wanted this amp before I knew I wanted this amp. I'm so excited. :D :D :D :D :D
Thanks for any additional info.
Jac
PostPosted: Sun Apr 15, 2007 4:28 pm
The EL84 are designed for an 8K load. If they see less their operating point will shift and they will transfer less power to the OT / speaker.
The result will be a sound with a bit of an edge to it and slightly lower power output.
Fortunatley, the Trinity transformer has 5K & 8K so you can accomplish both with the same OT and experiment or add a switch.
PostPosted: Sun Apr 15, 2007 5:38 pm
umm. so which would be better when I build it? Or is the switch the way to go so I can flavor to taste :D
Jac
PostPosted: Mon Apr 16, 2007 7:58 am
Jac
Build it using the low impedance as designed but add the switch if you want the option.
PostPosted: Mon Apr 16, 2007 12:36 pm
Do you have schem that shows how to add the switch to the chassis?
Jac
PostPosted: Mon Apr 16, 2007 1:07 pm
Easy. You need a DPDT 5A / 10A switch. # sets of terminals:
Common (2 terminals in the center) goes to Tubes, on impedance tap to one set of terminals, the other tap he third set.
PostPosted: Mon Apr 16, 2007 2:37 pm
Cool, thank you
 Post subject: TC-15 Test Drive
PostPosted: Tue Apr 17, 2007 9:20 pm
Hey everyone,
Thanks to coco, I got to take the TC-15 prototype for a drive. I have recorded a few clips, which I'll get to, but first the rig.
I plugged the head into a Traynor Bass cab with a single 8ohm 15 speaker (Don't know what it is, but its vintage 1970's). Not sure how many of you would do that so I won't go into detail on the sonic properties of the speaker and cab. Recordings were made with coco's attenuator to keep the family from complaining.
No effects used, natch! Guitars - Mid 80's Korean Squire Strat with Fender Lace Sensor pickups, Blue in the neck and middle positions and a Silver in the bridge position. I did the cleaner stuff with that on the Treble Bass channel, with some dirty stuff on the One track by switching the guitar cable(hence the pause).
Amp settings - In O'Clock (No markings on faceplate yet)
Code:
  Master     |                  Channel 1                            | Channel 2 (EF-86)
  Vol  |  Cut  |  Treble |  Bass  |   Vol   | Toggle switch | Contour |  Vol
  12   |  12   |    5    |   2    |   9     |     Down     |    12    |     5
Please be aware that I will never be mistaken for James Hetfield or any pro guitar player, so there's plenty of flubs...just so you know before you click.
Both tracks with the strat:
http://www.trinityamps.com/clips/JPclips/TC-15-Clean-UnderBridge.mp3
http://www.trinityamps.com/clips/JPclips/TC-15-CleanNDirtyOne.mp3
The following tracks were done with my 95ish stock Gibson explorer, which is a 76 re-issue. Only thing to say about he Explorer is I use Ultra heavy 12 - 54 Strings because I usually have it tuned down to B for the KoRn, Disturbed, etc, type stuff.
This clip is Metallica and Slayer tuned down:
http://www.trinityamps.com/clips/JPclips/TC-15-SadButTrue-DeadSkinMask.mp3
I tuned the Explorer to E (ish) for the Purple and Ozzy stuff:
http://www.trinityamps.com/clips/JPclips/TC-15-CrazyTrain-Master.mp3
http://www.trinityamps.com/clips/JPclips/TC-15-DPBS-Explorer.mp3
In summary this amp has plenty of versatility and gain enough even for a metal head like me, I'm sure I can dial in quite a range of sounds with this bad boy! I hope to try some and record some more sounds, maybe even without the attenuator this coming weekend! Just got to get the wife and kids out of the house for a while.
Thanks to coco for the opportunity to try this amp!
John.
PostPosted: Tue Apr 17, 2007 11:27 pm
Oh Oh, here comes the Metal Heads! :twisted:
Love that Deep Purple and Crazy Train stuff. You aint half bad dude :D You wanna jam some time? Yessiree, ya shur got yer ver-sa-til-ity!
Honestly, thanks for the clips JP. This really shows the TC-15 in a very different light. Really appreicate them. Looking forward to some more.
All please note: JP recorded this after using an attenuator into a 15" speaker.
PostPosted: Thu Apr 19, 2007 11:49 am
Ya know, sooner or later I see a road trip to Canada for a jam session.
What kind of attenuator was used for the TC. I still need to build one
Thanks, Jac
PostPosted: Thu Apr 19, 2007 12:04 pm
C'mon up!
What kind of attenuator was used for the TC. I still need to build one.
Auto-Transformer made from Radio shack part as posted here originally by bradvoka.
PostPosted: Thu Apr 19, 2007 12:50 pm
would be fun, maybe this summer. I'd really like to do this.
I actually hitchhiked across Canada in 1978, had a ball, The cleanest country I ever saw and very nice people. Ages me, doesn't it. :shock: :lol:
I've got the A-1045, right one? from rat-shack
PostPosted: Thu Apr 19, 2007 1:29 pm
Check out the post: viewtopic.php?t=783
