It is currently Thu Jul 18, 2024 5:31 pm
 Post subject: New build
PostPosted: Fri Sep 14, 2007 5:22 pm
Time to start gathering parts for a new fall/winter build. I built a Spitfire but really I'm not that crazy about it. I like the cleans but not the fizziness of the overdrive. The TC15 looks really interesting. Is there a comparison between the two? More clean headroom in the TC15? Fizziness in the OD? Where can I get a board for the TC15? Can I use the same West Labs iron that I have(I would presome that I can)? Lots of question here.
Hope someone can help.
Thanks in advance.
I think I'll build one of everything!
PostPosted: Sun Sep 16, 2007 8:33 pm
Never compared the two because I never built a Spit. The OD is not fizzy on the TC-15 but maybe put a MV pull switch to disengage the MV when you dont need it. The cut helps a lot to control the high top end.
Try defeating the MV on the Spit & see if it's still fizzy.
You can get a board from us of build one from the layout we posted. You can use the same West Labs iron.
PostPosted: Sun Sep 16, 2007 10:18 pm
Thanks, I'll give the MV switch a try first and see what thats like.
