It is currently Wed Jul 17, 2024 3:33 pm
PostPosted: Thu Nov 08, 2007 3:46 am
Ok first few shots - I'm hoping for at least a bit of sleep tonight; I have a four hour exam tommorow... good thing I had this amp to give me an excuse not to study! :P
Heres the result of my first work session:
Edit - Apparently my web host isn't working anymore... :( I'll find a way to get them up tommorow. Get some sleep fellow rockers!
PostPosted: Thu Nov 08, 2007 10:47 am
OK here we go - first three shots. 8)
http://home.comcast.net/~revv23/tc-1.jpg
http://home.comcast.net/~revv23/tc-2.jpg
http://home.comcast.net/~revv23/tc-3.jpg
Not bad for the first nights work eh? 8)
PostPosted: Thu Nov 08, 2007 11:48 am
Ok; so the cap that goes to pin1 V2 is labeled on the schem as .00015uf. The smallest value cap i've got is .0005uf...but that is for the tone contour. I also have a .0015uf cap; would it be safe to assume the .0015 cap is labeled wrong on the BOM? It's labeled as a 152k Cap.
PostPosted: Thu Nov 08, 2007 12:22 pm
OK Besides the cap value i cant figure out; the PCB is done; sorry ofr the blurry pics.
PostPosted: Thu Nov 08, 2007 12:28 pm
OK; took some better pics; the first ones didn't do it justice.
http://home.comcast.net/~revv23/tc-8.jpg
http://home.comcast.net/~revv23/tc-6.jpg
http://home.comcast.net/~revv23/tc-7.jpg
PostPosted: Thu Nov 08, 2007 4:45 pm
Sorry no pix! Just the little boxes with the red x
Stew
Hmm ...pasted the link into the browser and now all the pix work!
Stew
PostPosted: Thu Nov 08, 2007 9:20 pm
Whazzup with the pics? maybe scale them down a bit?
PostPosted: Fri Nov 09, 2007 2:03 pm
wierd they work fine with me... I'll put links to them in...
PostPosted: Fri Nov 09, 2007 3:05 pm
Pics are coming through now for some reason. Use the .0015 cap.
PostPosted: Mon Nov 12, 2007 12:49 am
Didn't get to work all weekend; too much tailgating to do. :)
Got quite a bit done in the last few hours however. Lots of pics tommorow. I only have the EF-86. cliff jacks, and two more pots to wire up and thats all she wrote on this big guy.
I'll have it finished next time i sit in front of her. 8)
This build was more difficult then the sIII; but with my experience is was much less frustrating, much more relaxing, and MUCH less time consuming. I just put on the grateful dead; went into a trance, and woke to the smell of cooling solder with dreams of the perfect tone ringing through my head. 8)
PostPosted: Sat Nov 17, 2007 12:54 pm
Got all fired up;
Have a cold joint somewhere i'm going to reflow the whole thing today.. otherwise it runs great; awesome sound. I have to get myself to unplug it so i can fixthe joint! Voltages are a bit out of whack too I think im getting alot more overdrive than was inteneded... I've went over the layout already and everything seems set up right so far. hopefully i'll find a mistake when im reflowing the joints.
Oh; and I think when i make my next amp i will put the jumper wires on the top of the PCB. I was worried I may have lost one and i had to remover the whole PCB (while it was wired up) to check! Luckily it was OK; but i realized that if i need to service those wires i will have to rewire most of the amp. Running over the top will completly eliminate that risk for me. :)
I have tons of pics... just no time. I have been very busy this week. I'll get them up soon i promise!
PostPosted: Sat Nov 17, 2007 6:42 pm
Way To Go! Another TC-15. Congratulations! :D
...getting alot more overdrive...
This is a high gain amp and very touch sensitive so if you play/stroke it hard, you're going to get plenty of overdrive. Try backing off on the git vol, using the low input and play it gently. Play with the master vol too. Leave it off and use the volume only.
Also, depends on which channel. If on channel 1, it will depend on your choice of EF86. Some tweaking of the values on that side may be necessary. There is a discussion on EF96 re: a DC-30 on the forum somewhere.
Well done!
PostPosted: Sat Nov 17, 2007 7:52 pm
Hey Steve; if it is indeed running right then i think i am happy; the sound is terrific. I am just thinking something is off because of the the volts i am running ( i was thinking about not searching for a missed connection; as that would mean i keep the crunch). Ill post the voltages up on this and my 18w soon hopefully. As for EF-86; i got a tung-sol EF-806...(EF-86's are NOT easy to find!) i'll look for the thread asap.
Overall I think this amp will get more play then the 18w. They are such different beasts though its really unfair to compare them.
PostPosted: Sat Feb 23, 2008 12:38 pm
Revv23, could you possibly post your voltages some time??
