It is currently Thu Apr 10, 2025 7:29 am
PostPosted: Thu Jun 05, 2008 2:48 pm
Stephen, what are the PT bolt spacing and cut-out measurements on your chassis? I have an old Hammond organ amp that I'm thinking about making into a TC-15, and I need to decide whether to try to shoehorn it into the Hammond chassis (very narrow), or perhaps buy one of your chassis if the Hammond PT will drop right in.
PostPosted: Fri Jun 20, 2008 2:48 pm
Crickets . . . alrighty, then . . .
PostPosted: Fri Jun 20, 2008 3:20 pm
drew, not to worry, Stephen will get back to you as soon as it is humanly possible - this guy is FAST at responding normally... I believe he's on the road right now with limited internet access, but believe me, as soon as he logs on you'll hear from him! :)
Brent Bodrug
Producer-Engineer/Songwriter
www.slyfichapel.com
PostPosted: Fri Jun 20, 2008 5:53 pm
I dont have this handy on the road but will look it up. Anyone have a bare one?
 Post subject: TC-15 PT spacing
PostPosted: Fri Jun 20, 2008 9:45 pm
Chassis PT cutout is 55.5 x 70 mm. Bolt spacing is 65 x 79 mm, with a little leeway (holes a bit oversized). The Trinity/Heyboer PT has its bolts spaced at 63.5 x 80 mm. This is from my Trinity kit, not yet assembled. Is this what you need? Hope it helps.
PostPosted: Sat Jun 21, 2008 8:27 pm
Yes, that was it, thanks.
