It is currently Thu Apr 10, 2025 7:10 am
 Post subject: TC-15 wiring question
PostPosted: Tue Jul 29, 2008 9:05 pm
Hi all,
On the TC-15 wiring diagram the EF86 socket has a wire from ground to pin 7, with a jumper to pin 2. My question is this: can the ground wire come from pin 2? It would seem not to make a difference because of the jumper, but I want to be sure.
PostPosted: Tue Jul 29, 2008 9:17 pm
You would still have to ground pin 7!
Hmm, as long as you stick with the schematic and ground pin 7, I don't see a problem (coco? )I don't see why you would want to change? The wire would be longer doing this (coco?) It makes more sense to stick with the original plan :?
PostPosted: Tue Jul 29, 2008 11:50 pm
It makes no difference - other than lead dress. I ran the ground wire to pin 2 on my build because the tube sockets I used were oriented differently than the ones used by Trinity. 8) Just make sure the jumper from pin 2 to 7 is still there.
DericĀ®
