It is currently Tue Dec 02, 2025 3:40 pm
 Post subject: Vibrobox anyone?
PostPosted: Mon May 02, 2005 8:45 pm
Anyone homebrewing the pedals? Curious about the Vibrobox because I think it's going to be the basis for a SE build w/ trem.
https://schematicheavencom.secure.powwe ... brobox.pdf
(Actually of two minds on the Vibrobox - just building one for general utility has an appeal, but tubes on the floor? And the fact that V 1 is using just 1/2 of the 12ax7 begs for some change, but the EF-86's are too prone to microphonics, and paralleling the second triode might be a bit too much. I dunno - relay swiching, plant in a box off the floor with selectable trem, selectable burn? Are relays too anti-Matchless? So maybe three minds - build one straight up, build one tricked out, or steal for a cool SE trem amp. Can you say option anxiety?)
Bear
PostPosted: Sat May 07, 2005 7:11 pm
I think s2 is the pedal guy. Maybe he's got something on the back burner?
PostPosted: Wed May 11, 2005 8:39 pm
Does anybody have a scheme for the RV-1 reverb, perhaps? I had the odd idea of using the West Labs SE iron to make a Vox/Matchless styled variant of the Fender 6G15 outboard reverb.
Bear
PostPosted: Wed May 11, 2005 9:55 pm
Sorry, no. Do have the Fender 6G15 outboard reverb schematic/layout tho if you need it.
