It is currently Mon Apr 07, 2025 2:00 pm
 Post subject: what ot for a spitfire
PostPosted: Sun Jan 10, 2010 11:49 pm
what the correct speck for the spitfire outputtrany? and what choke and if no choke what resistor thank mark
PostPosted: Tue Jan 12, 2010 10:41 am
The same as for the Matchless Lightning. The OT uses a 4k primary impedance. The Trinity OT has a 5k primary winding for that purpose, which is plenty close enough IMO. For choke and resistor options take a look at the TC-15 schematics in the Resources section.
PostPosted: Tue Jan 12, 2010 9:53 pm
i have some ots that were used with 6l6s id assume they were intended for larger power output, i guess ill give them a try if they dont work out ill have to order a few of the trinitys iv used 18watt iron in these amps while they sound ok iv alway had the feeling they wernt right thanks zp mark
PostPosted: Thu Jan 14, 2010 5:27 pm
Yeah, the Matchless tone depends on a lower primary impedance.
PostPosted: Thu Jan 14, 2010 10:16 pm
The 5K impedance does the trick for a Matchless Sound and the OT is highest quality too. You do get a bonus 8K for a smoother (Munch) sound.
