It is currently Sun Apr 06, 2025 3:05 am
PostPosted: Sat Jul 17, 2010 1:31 pm
Hi All. I could use a little help. I finally (over 7 months) finished up my TC-15 and fired it up this morning. The EF-86 channel sounds great. I have nothing on the normal side. No scratches, hiss, or hum when I move the pots. I took a look at the diagram and everything looks to be in place and I checked for cold solder joints. On valve 2, do I need to tie pin one, six, and seven together when not using the 100K metal film resistor? Any advice on where to start? I have a gig this afternoon, so I will check voltages tonight or tomorrow.
Thanks for the help
Harold
PostPosted: Sat Jul 17, 2010 2:25 pm
Get some pics up if you can.
Yes that 100K resistor needs to be there. It is a plate resistor, the plate is then direct coupled with the next stage's grid (which is a cathode follower stage).
PostPosted: Sat Jul 17, 2010 2:42 pm
That makes sense. The diagram had it listed as optional and it was not included in the kit. I'll pick one up, drop it in and report. Thanks Kurt
PostPosted: Sat Jul 17, 2010 3:20 pm
The diagram actually lists "Metal Film" as optional. Meaning you can use metal film composition instead of carbon composition. Metal film will be a bit quieter and maybe a lit clearer.
If you don't have that resistor installed that is why you don't have sound.
PostPosted: Sat Jul 17, 2010 9:01 pm
and you should have gotten one of each. Use the carbon comp if you have it.
..but I can see how you'd get confused with the "optional" wording
PostPosted: Sun Jul 18, 2010 4:36 pm
OK. So I found my 100K metal film resistor which was buried it in the box (sorry to imply it was not included). I installed it on valve 2 and fired it up. I now have sound, but it is VERY faint. I'm going to check the voltages on valve 2 to start. Any other suggestions? Thanks for all your help.
Harold
PostPosted: Sun Jul 18, 2010 7:42 pm
I figured it out. When I installed the 100K metal film, I had the resistor between the wrong pins. Fired up and sounds great. Thanks for all the help.
Harold
