tyejones wrote:
I saw in the Resources how you can install a bleeder (220kO 2Watt) resistor between B+ and ground to drain the power transformers. (will this affect my tone?)
No, too small a load to do anything tone wise.
tyejones wrote:
Do you have any suggestions for how I can drain the 22uf & 220uf Electrolytic Caps, or does this bleeder resistor handle that as well? (just trying to be sure I don't fry myself.)
The bleeder will drain all the HV caps. The 220uF cap see's 10V max, your safe touching that one.
tyejones wrote:
Are there any other safety precautions that you recommend?
When you turn the amp off hit a few chords, you'll hear the sound fade out. You just drained the caps yourself.
