It is currently Tue Apr 08, 2025 8:09 am
PostPosted: Mon Oct 25, 2010 9:04 am
When I put the contour switch in the full clockwise position there is a whooshing sound coming through the speaker. Anybody experience this?
PostPosted: Mon Oct 25, 2010 10:00 pm
No, I have never heard that. As you switch it or once it's switched?
PostPosted: Mon Oct 25, 2010 10:48 pm
Once it is switched.
PostPosted: Wed Oct 27, 2010 6:32 pm
Any particular position? Can be a lot of things, but maybe one bad solder joint. or even the EF86 tube. you need to determine exactly when it happens to isolate the problem area.
PostPosted: Wed Oct 27, 2010 6:52 pm
It only happens when the switch is in the furthest clockwise position, all the way to the right. Its not the tube, Ive tried 4 different ones and always get the same noise.
What components are in play in the far right position?
PostPosted: Wed Oct 27, 2010 6:56 pm
Only the one capacitor and the soldered connections. Reheat the ones for that component only.
