This amp was a labor of love, I have to say. I give special thanks to Anthony, of Reason Amps, Nik of Ceri@tone,TransformerDesignandSupply, Jeanne of BNP, as well as the people on this board, who helped me trouble shoot a problem with little hum.
I wanted a Spitfire, but didn't really want it in the Matchless style cabinet - I like the look of the Marshall 18w. Ceri@tone helped me with a chassis that fits the Spitfire innards into the 18w chassis config.
The cabinet came bare from Reason Amps just before they stopped selling them, and I covered it with Lizard Skin Tolex (ebay). The tubes are: GT Mullard 12ax7 for the preamp, GT Mullard Matched Phase Inverter 12ax7, two matched JJ EL84's.
There were only two hitches I encountered. The first was when I loaded my speaker, chassis, and went to install the tubes - the end bell of the BBQ Blue Dog AlNiCo was directly in the way of one of the EL84's. Short term solution was to remove the end bell, but that left maybe 1/4" between the tip of the tube and the magnet - not good.. Long term solution was to have a new baffle board made that centered the speaker between the two banks of tubes. Anthony came through once again, and I was on my way.
The second hitch was an annoying, nasty little hum. With some help from this forum that led me in the right direction, I located a ground buss that connected the filter caps to the screen resistor/cap. Breaking the link between them, and running the screen resistor to preamp ground solved that one.
The final touch was the faceplace. With a gold vent, cabinet string, and Marshall handle, I needed a gold plexi style faceplate. I found Jeanne at BNP, and she did a terrific job!
I love the sound of this amp! It sounds like a huge amp, only not so ear shatteringly loud (how loud can you get with 15w?). Band mates and fellow musicians have raved over the tone and dynamic response. For those small to mid-sized venues, this is my amp of choice.
Ok, here are the finished pics:
From the front:
From the back:
Top View:
Chassis:
Here's where I needed to separate the filter cap grounds from the screen resistor/cap:
I'm looking forward to tomorrow night when I get to gig with it again!
