It is currently Wed Jul 17, 2024 3:20 am
 Post subject: Spitfire w/ Reverb
PostPosted: Tue Aug 16, 2005 4:08 pm
Has anyone ever seen a schematic for a Spitfire with reverb, or know of a Matchless amp schematic that uses the same reverb circuit that would be installed in a Spitfire w/ reverb?
PJM
http://www.diyguitarist.com
PostPosted: Sat Aug 20, 2005 12:58 am
I haven’t seen a Matchless version, but I have used foldback reverb on two amps (one is a Lightning) with great results.
Eddie
PostPosted: Sat Aug 20, 2005 9:50 am
I think I remember reading a few posts by other people who added a foldback reverb their Spitfire/Lightning. I haven't heard anything negative about it, either. Do you have a schematic that you could point me to?
PJM
PostPosted: Sat Aug 20, 2005 7:18 pm
Sure, here is the schematic
This one works quite well (this is identical to what I have in my Lightning ), but you can always tweak components to get what you want. One change I would probably make is to use a 50k pot instead of the 25k, for a little more reverb.
Eddie
PostPosted: Sat Aug 20, 2005 10:18 pm
Thanks! 8)
PJM
PostPosted: Sun Aug 21, 2005 9:52 pm
IIRC, Matchless used the typical Fender topology for reverb. I think you can just rob it from any of the older Fender schematics.
--s2
www.s2amps.com
www.category5amps.com
PostPosted: Mon Aug 22, 2005 10:18 am
As in a Twin Reverb? I love the sound of that reverb! Cool. 8)
PJM
PostPosted: Tue Aug 23, 2005 2:37 pm
I didn't compare values, but the 'verb in the Chieftan looked like the blackface topology.
Bear
PostPosted: Tue Aug 23, 2005 4:11 pm
Cool, I'll look at the AB763 schematic and go from there. 8)
PJM
