It is currently Thu Jan 22, 2026 8:59 pm
PostPosted: Wed May 02, 2012 9:48 pm
Has anyone tried doubling the wattage of a Lightning by running 4 el84's. I have done the following:
The output transformer is beefy enough to handle the additional powe so I have no worries as far as that is concerned. I have not changed the design at all, aside from running 4 el84’s (compared to 2 in the original design).
What I did:
1. All I did was run both R20and R22 in series with the additional tube. So R20 went to tube 1 then in series to the grid (pin 2) of tube 2 and R22 went to the Grid of tube 3 then in series to tube 4.
2. C12 is run in series with the cathode (pin 3) of all 4 tubes
3. The plates are run in series with…similar to what I describer with the plates I described above.
4. And finally I have all 4 grids(pin 9) running parallel off the 33uf 450 v capacitor. – I think this might be my error.
I cranked it on and no real sound but some odd squeals. I didn’t really look at it much. But I wanted to see if this made sense to anyone - I do suspect I might way offbase.
PostPosted: Thu May 10, 2012 12:20 am
yalesmith wrote:
The output transformer is beefy enough to handle the additional power so I have no worries as far as that is concerned.
It's beefy, but not really enough for double the current draw. And also there's the PT to consider.
yalesmith wrote:
What I did:
The tubes should be operated in parallel pairs. Nothing in series.
Yes, that will kill all your drive signal. Where did you get the idea of putting a huge cap like that on the grids??
Users browsing this forum: Google [Bot] and 26 guests
