It is currently Thu Jan 22, 2026 1:12 pm
 Post subject: Output Transformer
PostPosted: Fri Aug 03, 2012 11:22 pm
Hi,
I am planning to build the Trinity 15 and have an SE output tranny on hand. It is a Mojo15wh. I believe it's a heyboer. Just curious if this transformer will work for the build.
Thanks for any help you can provide,
Doug
 Post subject: Re: Output Transformer
PostPosted: Fri Aug 03, 2012 11:38 pm
Won't work, you need a push pull output transformer.
PostPosted: Fri Aug 03, 2012 11:43 pm
BTW is this the same transformer you were asking about on 18watt.com? If so, the same applies as for a TC-15. You need a push-pull OT.
PostPosted: Sat Aug 04, 2012 9:57 am
Thanks! Any recommendations for an OT? I do want the 4K primary.
PostPosted: Sun Aug 05, 2012 11:31 pm
Ours has 5K and 8K so you can switch.
PostPosted: Mon Aug 06, 2012 7:09 pm
Thanks Stephen! I looked on your website and couldn't figure out how to order.
Doug
PostPosted: Mon Aug 06, 2012 7:35 pm
viewtopic.php?f=6&t=604
Email at address given in link
