It is currently Thu Jan 22, 2026 9:19 am
 Post subject: Diode rectified TC-15
PostPosted: Thu Aug 30, 2012 8:10 am
Has anyone tried diode rectification on this amp? I have a set of 18watt trannies that would do the job but have no 5v winding on the power transformer.
PostPosted: Thu Aug 30, 2012 2:52 pm
Keep the B+ in the 340 -360 range . It would be worth a try. I would expect it to be very tight sounding.
PostPosted: Thu Aug 30, 2012 4:03 pm
I'm gonna give that a blast. I'll report back soon. Thanks.
PostPosted: Fri Oct 05, 2012 12:59 am
Then just use an EZ81 for the rectifier. You'll be more likely to get DC voltages in the safe region.Alternatively, place a 120ohm 10W resistor before the first filter cap, to simulate the presence of an EZ81 and keep voltages under control.
When using SS rectifiers, it's highly advisable to use fast recovery rectifiers, such as UF4007s, to help reduce background buzz.
