It is currently Tue Dec 02, 2025 3:39 pm
PostPosted: Fri May 13, 2005 10:30 am
Considering this amp has a vox like front end it's no surpise that it sounds like this with a treble booster.
The booster was totally cranked. Settings were.
: High input
: Volume 3:00
: Bass Just a hair above 12:00
: Treble all the way down.
: Master less than 9:00 o'clock
I used a '62RI strat in the number two position. (You can hear the pickup selector change at the begining of the track. No Problem cutting through the mix with this setup.
http://www.trinityamps.com/clips/Trinit ... day_15.mp3
PostPosted: Fri May 13, 2005 10:41 am
What treble booster are you using on the amp?
PostPosted: Fri May 13, 2005 11:42 am
For this track I used a Cripsy Cream. I am, however, anxios to get a hold of one of s2's tube based models. Either way the TB brings out a whole new character in the amp. I have a Java Boost as well and that provides a tougher sound.
I can only imaging what at tube would sound like in this applications.
s2, email sent.
PostPosted: Fri May 13, 2005 8:18 pm
What kind of tube would you like me to stick in it before I ship it to you?
--s2
www.s2amps.com
www.category5amps.com
PostPosted: Fri May 13, 2005 8:35 pm
I'm anxious to get my hands dirty on some pedal-crafting when I get done with a few more amps...
The rangemaster is actually going to be the first one I build, being that it's such a simple design. I think I have a germanium transistor here in a box somewhere too!
After that, it's a ross compressor clone....
PostPosted: Fri May 13, 2005 8:57 pm
Man, I can hear those tubes just a ringin'. Sustain to the max!
PostPosted: Sat May 14, 2005 12:05 am
Hey s2. Stock is good. I am a tube swapping freak over hear. Although my keeley came with a second transitor I am all for more options valves provide.
PostPosted: Sun May 15, 2005 8:10 am
Ok. Of course, you can put anything in the 12A?7 family in there for a wide variety of sounds. I'm liking a GE (made in Holland) 12AU7 at the moment with the saturation and bias high. Yummy!
BTW, my beta tester offered to trade his Java Boost for the boost2 I loaned him. I won't quote him, but there was a lot of the use of the "F" word sprinkled with "GREAT!"
--s2
www.s2amps.com
PostPosted: Sun May 15, 2005 9:44 am
This is too funny. I just found the schematic for the java boost and I was going to set out and build one in the next few weeks...
I guess no mullard OC44 is going to take the place of a real tube! 8)
PostPosted: Sat May 21, 2005 1:21 am
12AU"Frekin"7 eh? I got a whack of those...mostly Ge's and RCA's. I will start saving my doh so I don't have to move and change my phone number when the pedal arrives. :twisted:
