It is currently Thu Jan 22, 2026 3:33 am
 Post subject: TC15 240v wiring
PostPosted: Mon Nov 12, 2012 3:55 pm
Hi guys,
I'm building my first Trinity Amp kit TC15.
I had a little question about wiring the transformer for the U.K 240v
I have familiarised myself with the transformer section of the manual and i understand it in principle. But I can't visualise how to physically do the connections.
In series the American way as per the layout black/red and black are twisted together soldered to the live tag. black/white and white are twisted and soldered to the Negative tag.
So how would this work in parallel? Black/white and white to the Live lug and black/red and white to Negative lug?
Thanks in advance!
Ben
 Post subject: Re: TC15 240v wiring
PostPosted: Mon Nov 12, 2012 11:45 pm
For 240V the PT primary coils are put in series.
This thread in the resources section may help!
viewtopic.php?f=12&t=3225
PostPosted: Tue Nov 13, 2012 6:57 am
Cool,
Thank you.
I have a question though. This diagram has the white and white and white/black revered, compared to my transformer (my transformer is the same as the layout in the manual).
i.e my transformer
0 is white 117 is black 0 is white/black 117 is red/black 290 is red 0 is red 290 is red.
transformer in 240v diagram is:
0 is white/black 117 is black 0 is white 117 red/black 290 is red 0 is red 290 is red
Do i have the wrong transformer? if not. Do i go with the wire coding or with the order the wire come off the transformer?
Ben
PostPosted: Tue Nov 13, 2012 11:31 am
In that diagram if you go by the schematic of the transformer the layout shows the correct wiring.
In your case where
Black 117V
White 0V
Red/Black 117V
White/Black 0V
Then the White and Red/Black are connected together and your Black is your + 240V (live/hot) and your White/Black is your - 0V (neutral).
Email Trinity to confirm this.
