It is currently Fri Jan 23, 2026 12:48 pm
PostPosted: Thu Mar 28, 2013 8:25 pm
I am building TC-15 with VRM. This is my first amp build ever.
I can't seem to find a doc that shows where/how to wire in the VRM. Does the pot replace a stock pot in the build?
If anyone can point me to a range of photos or graphic layout, I would very much appreciate it!
Zen Solderer
PostPosted: Fri Mar 29, 2013 10:44 am
Heres one in an 18 watter (same chassis). Should have come with a switched pot so you can replace the power switch or wire the pot in the back like this one. (your choice) if you do a forum search for "VRM" you should come with a few examples in other amps
viewtopic.php?f=7&t=3140
PostPosted: Tue Apr 02, 2013 11:24 pm
Look In the resource section and chech out this search. search.php?keywords=VRM&terms=all&author=&fid%5B%5D=1&sc=1&sf=titleonly&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
PostPosted: Wed Jun 05, 2013 2:37 pm
Barring having done something stupid--like confusing pot terminals--the VRM installation was much less difficult than I made it out to be initially. Stephen was a huge help, in steering me to the right docs and patiently answering poorly worded emails!
I replaced the Power Switch, and I could not solder the pot to the VRM board and make a good connection to the chassis for the MOSFET, in that location. So, I mounted the VRM board to the chassis, directly under the pot and ran short, twisted wires, from the pot to the VRM board.
Below is a crap photo, taken late last night, on my phone. I will post better photos of my project, when it's finished, and I can confirm that I am not posting photos of bad implementations ;-)
Zen Solderer
