It is currently Wed Jan 21, 2026 8:44 am
 Post subject: Clean Headroom TC15
PostPosted: Tue Oct 21, 2014 3:01 am
Hi folks!
Im interested how much headroom does this amo have?
I Know it packed with loads of crunch tones but Im interested if it can produce nice cleans at higher volumes?
SOmethink like this maybe?
https://www.youtube.com/watch?v=Jq3KBpC4dh0
Does you amo come with a switchable power , 15 to 7W?
I see that every chanel has two inputs (hi and low)Whats the difference between them?
Any good video demonstartions of this amp?
I only find some audio clips on your site :-(
Thank you very much.
 Post subject: Re: Clean Headroom TC15
PostPosted: Tue Oct 21, 2014 2:51 pm
This is good demo checkout both clips
viewtopic.php?f=10&t=3502
PostPosted: Wed Oct 22, 2014 3:10 am
Ive seen that clip and the other one, but sound is poor.
Guy said that it was recorded with an iphone standing near the amp.
When the amp starts to drive it get fizzy as hell probbaly due the iphone mic.
Realy want to see some more demonstartions of this amp.
PostPosted: Wed Oct 22, 2014 9:48 am
http://www.trinityamps.com/Trin15Sound.htm
** b0b0 **
- This Space For Rent -
PostPosted: Mon Dec 29, 2014 5:06 am
Thanx!
Can you please explain the two channels on this amp.
Is this like on one chanles the Spitfire an on the other the VOX AC boost or this is wrong?
PostPosted: Tue Dec 30, 2014 3:28 pm
Sure....there is really no Spitfire channel per se. This is really a 15 watt Tweaked AC30/AC15/ Matchless DC30
The TC15 is a two channel TC15 hand-made 15 watt amp with two VOX derived channels. It has two very different channels. One is sweet and one is tough. Channel 1 is essentially an EF86 AC15 voiced channel while channel 2 is a high gain AC30 top boost preamp. The TC15 has similarities to a Matchless DC-30 with more tonal options. The amp has enough volume to fill mid-size rooms.
Common to both channels is the pull-on master volume and cut control. On the rear there is a 'Crunch' / 'Munch' toggle switch that changes the tone of the entire amp from Smooth to Crunchy and provides players with a whole new tonal palette.
Channel 1 - The EF86 channel brings a new world of crunch and munch. That channel has a wonderful, meaty, midrange gain but, when you roll back the volume, it cleans up very well. It has a Volume and tone contour 6 position switch. The contour switch that takes you from Fat to Thin tone in 6 steps. NOS tube is a must-have here!
Channel 2 - On this channel the original Trinity 15 sound remains with it's high gain and clarity. This is an amplifier with a smooth tone that won't fatigue your ears, even at high volume. At low volumes, it produces a clean and clear sound. The simple, yet interactive Bass and Treble controls provides endless tone options – enabling you to produce sparkling clean country sounds or VOX chime.
Channel 2 also has a Hi/Lo gain switch. This switch is subtle, but in use really not so subtle. With a Les Paul, it may mean the difference between being able to get a truly clean tone or not - amazing and VERY useful. With a Strat, it not only cleans up the tone a bit, but also makes the amp sound like it had less headroom - a bit like the "bold/spongy" switch on a Mesa. This is cool because even though there are plenty of clean Strat tones as it is, this gives a different flavor of clean.
