It is currently Tue Dec 02, 2025 3:11 am
 Post subject: Add-on reverb
PostPosted: Sat Oct 06, 2018 2:57 pm
Has anyone added a spring reverb to their TC15?
I'd be interested in a circuit to do this.
I realize more room would be needed in the cabinet, but I'm planning on making my own cab so that's not a problem.
 Post subject: Re: Add-on reverb
PostPosted: Sun Oct 07, 2018 8:52 am
This is the kind of thing I was considering.
PostPosted: Tue Oct 16, 2018 10:35 am
OK, I've figured out some of the details of how this would work, but still a couple of questions.
The original Fender amp this circuit was designed for apparently had a series of filter caps, and B+ was tapped at 3 different places in the series, resulting in B+1 B+2 B+3, all with different voltages.
The TC15 uses a can cap, and only has one B+ output. The reverb circuit wants 390-460 volts for B+2, whereas the TC15 only has a single plate voltage supply at 386 volts
I'm wondering
1) is 386 close enough to 390 that I can get away with this? It looks like I would be slightly under-powering the plate voltage for the 12AT7 tube. What would that be likely to do?
2) If I need to get that plate voltage in spec, how would it be possible to up the voltage coming off the TC 15's can cap?
Other wonder:
Robrobinette says this will draw about 1 amp of heater current.
Will this extra load cause problems in the TC15's power supply?
PS - I realize any answers would be speculative and I won't hold anyone responsible if my amp blows up :bugeye:
PostPosted: Tue Oct 16, 2018 3:25 pm
OK, I heard back from Rob Robinette himself.
He says there's no problem under-powering the 12AT7.
So the B+ voltage supplied by the TC15 power supply will be fine.
My only remaining question: will I cause problems by drawing this extra 1 amp off the power supply?
PostPosted: Fri Oct 19, 2018 10:15 am
Update 1: Ordered my TC15 Kit!
Update 2: found some old threads with Kurtlives' reverb circuit. It looks similar to the Fender derived one above.
Would love to hear from anyone who has tried the Kurtlives circuit, how it turned out, any tips or suggestions, what components you used.
Schematic attached below.
I don't see where he says what kind of tubes these are.
Maybe there is a code for tubes on schematics that I don't know how to read?
It looks like he's got his RCA jacks grounded on both sides of the tank - so I am guessing this means it goes with a reverb tank that's insulated on the input and output sides?
