It is currently Wed Dec 17, 2025 4:15 am
 Post subject: Fixed Bias?
PostPosted: Wed Apr 19, 2006 11:33 am
Anyone try a fixed bias conversion? What would it take and how would it sound? Is it worth a try?
PostPosted: Wed Apr 19, 2006 2:16 pm
I have used fixed bias in several 18 watt style amps and the Lightning isn't all that different in the basic power amp. All it takes is a pot (optional) and a few resistors and caps. You can can see a circuit in the Vajra build under DOWNLOADS/MODS on the http://www.18watt.com forum.
The difference in sound is mostly in the low end. The amp becomes tighter and has a less loose low end. The Vajra build has a switch to switch between modes.
Another place to look is at the Marshall Park and 20 watt amp scheamtics. One or two of those used a fixed bias arrangement.
Richard Johnson
