It is currently Sun Apr 05, 2026 1:39 pm
 Post subject: TC15 indicator fail
PostPosted: Wed Sep 04, 2019 5:51 am
Hi,
Finished wiring power section. All voltages on spec. Indicator light does NOT turn on. It flashes for a split second when amp is turned OFF. I'm reading 117.4V across, but that should be good enough right? Is it safe to assume the indicator is faulty? Thanx.
 Post subject: Re: TC15 indicator fail
PostPosted: Thu Sep 05, 2019 11:08 am
Dunno if this will help but in my experience the plastic housing is very soft and easy to damage with heat when soldering, I destroyed mine when soldering wires to it and it would be intermittent in a similar manner.
PostPosted: Thu Sep 05, 2019 11:20 am
Thanx. I guess I'll replace it and try to be super quick with the iron. Though there is no visible damage.
PostPosted: Sun Sep 08, 2019 8:34 am
In the ON position, there should be half your mains voltage if it is wired correctly. So if you have 235 mains, you will get 117V , which is fine.
