It is currently Fri Oct 23, 2020 4:44 am
 Post subject: switch pop
PostPosted: Sat Dec 28, 2019 8:47 pm
My contour switch pops in 2 position. Also the crunch switch in the rear of the amp. I've been poking around with a chopstick and can't seem to find any6. Any suggestions as to where to look?
 Post subject: Re: switch pop
PostPosted: Sun Dec 29, 2019 8:34 pm
The 5.4M resistor should stop the pop so you can try reheating the joints up. Its alos a make before break switch which really should inhibit any pop
Put a shunt resistor 2.2M to ground --> across boost switch.
PostPosted: Fri Feb 14, 2020 6:06 pm
Is there any to show me a diagram on how to do shunt the switch?
