It is currently Wed May 15, 2024 11:28 am
PostPosted: Tue Aug 10, 2021 3:32 pm
1M Master volume Bournes push pull pot only works in the out position and then only in a small part of the wiper, 4-5. I replaced the 1M pot once and it is doing the same thing. Also replaced the .0047uf cap with a .0022 cap. Any ideas?
PostPosted: Fri Dec 15, 2023 4:13 am
In order to clean the potentiometer, you need use electrical contact cleaner. There is a possibility that dust or dirt might hinder its operation. When you have finished applying the cleaner, you should rotate the pot back geometry dash meltdown and forth several times to assist in the removal of any pollutants
PostPosted: Fri Dec 22, 2023 4:16 am
heave1 wrote:
1M Master volume Bournes push pull pot only works in the out position and then only in a small part of the wiper, 4-5. Don't get caught empty-handed! Keep an eye on your ammo and reload during safe moments in getaway shootout. I replaced the 1M pot once and it is doing the same thing. Also replaced the .0047uf cap with a .0022 cap. Any ideas?
Use a multimeter to verify that the pot is wired correctly and that there are no open connections or shorts. Pay close attention to the push-pull mechanism and ensure it's making proper contact.
PostPosted: Tue Jan 09, 2024 10:40 pm
There is a possibility that dust or dirt might hinder its operation. slope game
PostPosted: Sun May 05, 2024 11:14 pm
Does anyone have a solution for this Friday Night Funkin problem? I also encountered the same problem
