It is currently Tue Jan 20, 2026 9:20 pm
 Post subject: Lightning vs. Spitfire
PostPosted: Mon Apr 04, 2005 2:56 am
Is there much difference tonewise, other than the Lightning having a way more versitile tone stack?
Thanks for any input,
Denny :D
PostPosted: Mon Apr 04, 2005 1:10 pm
from what I've read, i believe that the lightning can get a little bit dirtier than the spitfire. They're both bright amps obviously but the lightning can get a little bit deeper into 'edgier' territory
steven, correct me if i'm wrong! :D
PostPosted: Sun Apr 10, 2005 11:10 pm
The Spitfire can get plenty dirty with its 1st trioide running hot and in parallel. the biggest difference is the MV. With the Lightning, you can coax the preamp into overdrive with the MV set low. The only way to get a Spit to act dirty is to crank her up! Of course, there is also that tone stack thing...
--s2
www.s2amps.com
www.category5amps.com
redacted
--s2
www.s2amps.com
PostPosted: Sun Apr 10, 2005 11:53 pm
why is it redacted? is it not true anymore? hehehe :D
PostPosted: Mon Apr 11, 2005 1:26 am
8)
The easiest way to build a Marshless SpitPlexi is to build a WoodCross Thunderbolt 9. :arrow:
It's the most versatile "Spitfire" around.
CR ><>
PostPosted: Mon Apr 11, 2005 4:40 am
Sweet looking amps you have there Maccabee!!!!!! :)
PostPosted: Mon Apr 11, 2005 12:39 pm
That's pretty much my assessment as well. It's kind of like a Twin Reverb, but not as extreme. 8)
PJM
http://www.diyguitarist.com
PostPosted: Mon Apr 11, 2005 11:02 pm
8) Thanks Man. Wish I could keep em but they belong to customers. Trinity did that combo cab. Did a great job on it.
CR ><>
WoodCross Amps
PostPosted: Mon Apr 11, 2005 11:09 pm
8)
Actually, there is a Normal and Boost Switch on my amps that adds a bit of earlier breakup to em. The Amps retain their Voxy heritage but with SS Recto and a 1K Resistor in place of the Choke, it allows em to act a bit like a Plexi. The Marshall !8 Watt OT is a bit dirtier than the MAtchless/Vox trannies too.
CR ><>
WoodCross Amps
PostPosted: Mon Apr 11, 2005 11:21 pm
That's cool, How does that work? and did you cathode bias the 6V6 hotter than normal?
PostPosted: Tue Apr 12, 2005 11:09 am
Stephen;
No! The Thunderbolt 8 (2X6V6)already has a rail voltage of almost 400 VDC and the Thunderbolt 9 (2xEL84) runs at 348 VDC. It's an idea that Zophod Phil gave me at 18 Watt.com. Drop the value of Shared Cathode Resistor on the PI. I use parallel resistors and make it switchable.
CR ><>
WoodCross Amps
PostPosted: Tue Apr 12, 2005 11:22 am
Sounds like an interesting combo. Also, that's a cool idea about the normal/boost switch. I haven't been over to 18watt.com for a while, but a lot of cats seems to really love the 18 watt Marshall. 8)
PJM
PostPosted: Tue Jan 16, 2024 4:08 am
Sounds like a worthwhile combination. That's a really good concept with the normal/boost switch, too. Although I haven't visited 18watt.com in a while, it appears that many cats genuinely adore the 18 watt Marshall.
retro bowl college
