It is currently Sun Dec 14, 2025 12:12 am
PostPosted: Sun Jul 22, 2007 5:05 pm
I'm interested in seeing what the amp's like without the master. I've been reading that it's more transparent. To remove the master, would I just disconnect the red and blue wires from the board? that run to it? If I wanted to keep the cut would I just route those two wires to the cut control instead? Blue goes to pin 3 of the cut control and red goes to pin 2?
PostPosted: Mon Jul 23, 2007 7:07 am
Suggest you switch it out but if you are moving wires, you just need one send & one return to feed the cut. Same two wires that feed the master - moven them over to the cut. Follow the schematic.
PostPosted: Mon Jul 23, 2007 1:09 pm
Thanks, Stephen. Thanks for the schematic reminder, too. I need to get into the habit of using them.
