It is currently Fri Apr 18, 2025 3:32 am
PostPosted: Tue Jul 24, 2007 2:17 am
I just followed the entire Lightning and Jennings era AC30 (normal channel) schematics. I think I've noted the differences I saw before, but there are some more. These are where the Vox differs from the Lightning (other than power handling, obviously):
C1: 500pf (from .0015pf)
C3: 100pf (from 180pf)
C4: omit from Lightning
C5: 50uf (from 51pf)
C7 & C8: .047uf (from .01uf)
C9 & C11: .0150uf (from .02uf)
R11: 220k (from 100k)
R21: 50 ohm (from 120 ohm)
Vol Pot: 500k (from 1M)
Master vol: omit from Lightning
C7, 8, 9, and 11 are coupling caps and change to some values I'm familiar with, but C5's change from 51pf to 50uf seems totally weird. That's an absolutely massive value difference. Is this bizar, or is it just my first time seeing something like that? I wish I knew how changing those coupling caps would effect sound.
PostPosted: Tue Jul 24, 2007 2:52 am
will this make a lightning sound more like the ac 30 ?
PostPosted: Tue Jul 24, 2007 3:36 am
I would imagine so. Not sure how the power section willl effect the sound. $10 in parts to try though. The 50uf is just what boggles me.
PostPosted: Tue Jul 24, 2007 12:26 pm
Paisley, have you heard the Lightning? It sounds great. I'm just interested in tweaking to learn what the different values do now that I have such a good reference in the Lightning.
PostPosted: Thu Jul 26, 2007 7:06 am
I'll see what infor I can provide when I get a bit of a chance..
PostPosted: Fri Jul 27, 2007 3:20 am
That'd be cool, Stephen.
Oh, and the wires linking pins on V1 aren't there either.
