It is currently Fri Apr 18, 2025 3:32 am
 Post subject: Wire cage for TC-15 amp
PostPosted: Mon Aug 13, 2007 2:07 pm
I'm building a trinity-TC 15 amp and am wanting to cover it with a wire cage so the glowing tubes can be seen. Has anyone any idea where I could get a wire cage?
Catch a big one
PostPosted: Mon Aug 13, 2007 7:28 pm
Will depend on the chassis size if a Hammond would fit, but you will have to see if you can bend it out of material you might be able to get at a sheet metal supplier. I'm sure they can bend it for you too.
 Post subject: wire cage
PostPosted: Mon Aug 13, 2007 7:40 pm
Thanks, Stephen. I'll check with a sheet metal manufacturer...
Catch a big one
