It is currently Tue Mar 31, 2026 3:46 pm
 Post subject: Power up question
PostPosted: Mon Apr 18, 2011 9:15 am
Finished my 5E3 build and after double checking all connections I decided to power up. With both standby and power switches on and no tubes installed I have the following readings;
Pin 2 = 5.35 VAC
Pin 4 = 352 VAC
Pin 6 = 352 VAC
Pin 8 = nothing
Heater wires and indicator lamp = 3.27 VAC
Should I not be reading 6.3 VAC for the lamp and heater wires. I also noticed the lamp sometimes flickers. This is my first build and I have very limited electrical knowledge so and help is appreciated.
 Post subject: Re: Power up question
PostPosted: Mon Apr 18, 2011 10:16 am
All those voltages look good!
You won't get a high voltage on pin 8 until you plug in the rectifier tube (5Y3).
When you measure pin 2 and 8 with one lead on ground and your DMM set to AC voltage you get around 2.5V AC right?
Heaters should measure 3.3V AC from heater to ground so your good there. If you measure from one heater to the other (or across the lamp) you will see 6.3V AC.
Flickering would indicate a loose connection/wire or a poor solder somewhere. Go through and check all your heater connections, make sure everything is solid, no bad solder, no partially broken wires, etc.
PostPosted: Mon Apr 18, 2011 11:12 am
Thank you.
1) With both standby and power switches on and no tubes installed - When I put one lead to ground (chasis) and the other to pin 2, I get 5.35 VAC and for pin 8 no reading... I do not get the 2.5 vdc...
2) Here are all my readings with all tubes installed. Can you please confirm these are correct, I am wondering about pin 7&8 0n V2
AC mains = 115.7 vac
B+ with no tubes = 0, with rectifier only = 482 vdc, with all tubes = 399 vdc
V1
Pin 1 = 138.5 vdc
pin 2 = 0
pin 3 = 2.2 vdc
pin 4&5 = 3.0 vac
pin 6 = 130.3 vdc
pin 7 = 0
pin 8 = 2.2 vdc
pin 9 = 3.0 vac
V2
pin 1 = 167.7 vdc
pin 2 = 0
pin 3 = 1.39 vdc
pin 4&5 = 3.0 vac
pin 6 = 212.2 vdc
pin 7 = 19.6 vdc ???
pin 8 = 52.3 vdc ???
pin 9 = 3.0 vac
V3
pin 1 = 0
pin 2 = 3.0 vac
pin 3 = 392 vdc
pin 4 = 356 vdc
pin 5&6 = 0
pin 7 = 3.0 vac
pin 8 = 21.8 vdc
V4
pin 1 = 0
pin 2 = 3.0 vac
pin 3 = 391 vdc
pin 4 = 353 vdc
pin 5&6 = 0
pin 7 = 3.0 vac
pin 8 = 21.8 vdc
Rectifier
pin 2 = 397.7 vdc
pin 4 = 334.9 vac
pin 6 = 335.3 vac
pin 8 = 398 vdc
PostPosted: Sun Apr 24, 2011 1:43 pm
I would assume the amp is working? With those voltages, it should be.
Yes perhaps a little low on V2,pin 8 but I have seen it similar voltages like that and it sounds great.
PostPosted: Sun Apr 24, 2011 1:59 pm
Yes it works and it sounds awesome! lovin it. When I first powered it up I had no sound but later discovered it was a bad guitar cable. I think my kids were messing around with the cable and broke a connection. I resolder it and bingo - what a relief. Thanks for checking the voltages, just wanted to make sure everything was close to spec. Excellent kit and extremely quiet.
