It is currently Sun Jan 18, 2026 1:49 am
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Fri Apr 25, 2014 8:16 am
Thanks for the feedback. The amp is great.
On the cabinet, the holes are usually tight fitting, but they could be a bit loose allowing the head pull in. I / you can look for a Truss head machine screw 10-32 x 1-1/4. This is a wider than normal sized head.
For the feet, they are probably screwed into the seam and that can cause some irregularities. See what the gap is on a flat floor and then maybe put a washer between the foot rubber and the cabinet to shore it up. Or we can send another foot (I don't expect that to solve the problem though.)
