It is currently Fri May 09, 2025 6:10 am
PostPosted: Sun Jun 06, 2021 11:43 am
My MM is reading continuity between both green heater wires and the green-yellow wire (that is meant to go to ground). I don't think this is normal. This is my first amp build. When I went to test voltages, I got mostly very low values.
PostPosted: Tue Jun 06, 2023 11:30 pm
I have the same issue. Did you solve it?
the backrooms game
PostPosted: Wed Sep 13, 2023 4:01 am
This article describes the causes and solutions that interfere with the normal operation of the power transformer failure of the transformer.
car games
