It is currently Sun Sep 13, 2026 5:12 pm
PostPosted: Fri Jan 12, 2024 7:22 pm
When I begin powering on and begin testing with no tubes in place, all is well when the Power Switch is on, but Standby Switch is off - voltages where they are supposed to be at all check points. When I install a rectifier tube, power on and hit the standby switch, the tube turns quickly hot red, the fuse blows, & the tube is shot. I've checked the wiring numerous times, run continuity tests, and can't seem to find a obvious short. I've gone through 3 rectifier tubes at $23 a pop.
Any ideas on what might be the problem? Or how can better diagnose the problem?
This is my second Tweed build from a Trinity kit. The first one works well.
PostPosted: Thu Feb 22, 2024 6:07 am
Doc Mock wrote:
When I begin powering on and begin testing with no tubes in place, all is well when the Power Switch is on, but Standby Switch is off - voltages where they are supposed to be at all check points. When I install a rectifier tube, power on and hit the standby switch, the tube turns quickly hot red, the fuse blows, & the tube is shot. I've checked the wiring numerous times, run continuity tests, and can't seem to find a obvious short. I've gone through slope 3 rectifier tubes at $23 a pop.
It's concerning that your rectifier tube is overheating and blowing the fuse when you switch to standby.
Always unplug the amplifier before working on it.
Double-check your wiring for any shorts or loose connections before powering on.
Replace blown fuses with the correct type and rating.
PostPosted: Sun May 12, 2024 9:39 pm
Doc Mock wrote:
When I begin powering on and begin testing with no tubes in place, all is well when the Power Switch is on, but Standby Switch is off - voltages where they are supposed to be at all check points. When I install a rectifier tube, power on and hit the standby switch, the tube turns quickly hot red, the fuse blows, & the tube is shot. I've checked the wiring numerous times, run continuity tests, slither io and can't seem to find a obvious short. I've gone through 3 rectifier tubes at $23 a pop.
Reach out to the manufacturer of the Trinity kit for assistance. They may have encountered similar issues in the past and can provide specific guidance based on their expertise.
PostPosted: Thu Jun 13, 2024 12:22 am
When dealing with electrical or electronic equipment, experiencing blown fuses or rectifier Pokerogue tubes can indicate underlying issues that need to be addressed promptly to prevent further damage.
PostPosted: Sun Dec 22, 2024 11:15 pm
otis wrote:
Doc Mock wrote:
When I begin powering on and begin testing with no tubes in place, all is well when the Power Switch is on, but Standby Switch is off - voltages where they are supposed to be at all check points. When I install a rectifier tube, power on and hit the standby switch, the tube turns quickly hot red, the fuse blows, & the tube is shot. I've checked the wiring numerous times, run continuity tests, Geometry Dash Free and can't seem to find a obvious short. I've gone through 3 rectifier tubes at $23 a pop.
How do I contact the Trinity kit manufacturer for support?
