It is currently Sat Mar 14, 2026 1:03 am
PostPosted: Mon Aug 23, 2021 11:37 pm
I see on some pics of Tweeds where is a small screw & washer in the centre of the board where it attaches to the chassis. Our chassis has a hole but is it meant for a screw? I see no mention of one.Thx.
PostPosted: Wed Mar 19, 2025 9:50 pm
I see on some pics of Tweeds where is a small screw & washer in the centre of the board where it attaches to the chassis. Our chassis has a hole but is it meant for a screw? I see no mention of one.Thx. brawl stars online
If your chassis has a hole that aligns with the board but there’s no mention of a screw in the documentation, it could be an oversight or simply a design choice that varies by model.
PostPosted: Tue May 20, 2025 3:21 am
Dave Little wrote:
I see on some pics of Tweeds where is a small screw & washer in the centre of the board where it attaches to the chassis. Our chassis has a hole but is it meant for a screw? I see no mention of one.Thx Geometry Dash.
That small hole on the chassis is indeed meant for a screw to secure the upper real plate. The screw and washer you’ve seen in photos help keep the plate firmly attached and reduce any movement. Even if it’s not always mentioned in manuals, adding that screw is a good idea for stability and longevity. Just make sure to use the right size to avoid any damage!
PostPosted: Wed Oct 15, 2025 11:55 pm
curlyfardage wrote:
Dave Little wrote:
I see on some pics of Tweeds where is a small screw & washer in the centre of the board where it attaches to the chassis. Our chassis has a hole but is it meant for a screw? I see no mention of one.Thx Melon Playground.
I agree with you!!
PostPosted: Mon Jan 26, 2026 10:20 pm
carmenstoffel wrote:
I see on some pics of Tweeds where is a small screw & washer in the centre of the board where it attaches to the chassis. Our chassis has a hole but is it meant for a screw? I see no mention of one.Thx. fish it!
So, which models support a chassis with a hole aligned with the motherboard?
