It is currently Tue Mar 31, 2026 11:47 am
PostPosted: Sun May 20, 2007 12:39 am
Hey guys
Theoretically here, what would the following tweak do to the tone?
Change cathode cap/resistor combo (the cap and resistor running to pin 3) of V1 and V2 from:
820k/25uf to 1.5k/4.7uf on V1
and
1.5k/25uf to 1.5k/47uf on V2
PostPosted: Mon May 21, 2007 8:22 am
Typically, lowering the resistor will increase the gain and increasing the cap will permit more frequencies to pass. Increasing the cap value could be like incresing the distortion for a wider sound spectrum. 25uF would be pretty broad and 0.68 uF quite focused.
For example, the boost switch in the sIII drops the resistance and adds a cap when engaged.
