It is currently Tue Mar 31, 2026 12:58 pm
 Post subject: The cabs have arrived!!
PostPosted: Wed Nov 12, 2008 11:02 am
Just received my deluxe cabs last night(will post pics tonight). One has a 12" baffle the other a 10" baffle. cabs are mades of solid pine (including the back pieces) and the baffles are made of void free baltic burch plywood. All joints are dove tailed. these things look so good i don't think I will be covering them with tolex, instead I think a nice stain job will do.
and hopfully I will be able to geet some grill cloth today to cover the baffles.
Also:
speakers are a Eminence legend 1058 ceramic 10"
and a Eminence Red, white, and Blues for the 12"
I will try to record sound clips when the amp is in the cabs
PostPosted: Wed Nov 12, 2008 6:40 pm
Clips are always good!!
PostPosted: Mon Nov 17, 2008 2:47 pm
Sorry for the delay guys I gut held up with the staining of one of the cabs, I went for red mahogany, and I'm finishing it with 2 coats of Minwax finishing paste.
PostPosted: Sat Nov 22, 2008 4:33 pm
PostPosted: Sat Nov 22, 2008 4:35 pm
I have noticed that my power tubes and rectifier are making a loud rattling noise, any recommendations to reduce this? (the cheaper the better..lol)
PostPosted: Thu Nov 27, 2008 8:41 am
Amp completed.
PostPosted: Thu Nov 27, 2008 10:29 am
F@#$ :shock: I'm at a loss for words. :wink:
PostPosted: Thu Nov 27, 2008 2:48 pm
Thanks man, The next one will turn out even better.. :wink: ...one one problem now I think the tube socket for V2 is bad..:-(...I have a spaire fo I'm going to wire it up tonight and hope it fixes the issue
PostPosted: Thu Dec 04, 2008 12:42 pm
Update: The tube soket was fine, it turnout that The shielded wire shielding was contacting the pin grounding it out. as for the rattles, It seems that I have to tighting up all the screws in the chassis
PostPosted: Thu Dec 04, 2008 10:23 pm
Sometimes the rectifiers can rattle. I can send you a couple of O rings that might help if you think that's a problem.
Yes, make sure the screws are tight please! and there is a thread on tracking down cabinet rattles here:
http://www.trinityamps.com/phpbb/viewtopic.php?t=12
PostPosted: Thu Apr 09, 2009 9:40 am
stain the baffle! :)
