It is currently Fri Jan 30, 2026 4:25 pm
 Post subject: Work in progress
PostPosted: Mon Feb 09, 2009 4:32 pm
Hi,
Started working on my deluxe thought I share some pic’s of the progress, got the chassis and trafos from Stephen. Planning on adding a vvr but instead of having the control on the faceplate I’m planning on mounting a heat sink and the pot on the back panel of the amp. I also planning on using a 220v light bulb instead of the 6,3v running of the heater wires . And planning of connecting the heaters right on the 6v6 instead of going all the way around the trafo, any thoughts on this?
http://www.burningheart.com/_lib/util/s ... =2517&s=hi
PostPosted: Mon Feb 09, 2009 9:11 pm
Chassis should be heat sink enough for VVR. 6.3 direct to 6V6 is good.
Love the amp cradle, talk to me about it!!
PostPosted: Tue Feb 10, 2009 5:58 am
Hi,
The cradle’s legs is made of 25mm(1”) alu, the small parts is also made of alu.
The rotating parts is made of stainless steel , the crossbar is steel . the plastic parts is from and office chair. Very simple to build if you have access to a metal lathe and a saw whit a alu blade and of curse some patience.
PostPosted: Sat Feb 14, 2009 9:53 am
Still working, see if i can get some more don to day.
PostPosted: Sat Feb 14, 2009 10:25 am
Awesome job malt. Nice shop you got going there. Very good ideas on that cradle.
PostPosted: Sat Feb 14, 2009 8:17 pm
Beautiful,clean work.
PostPosted: Mon Feb 16, 2009 11:52 am
Hi ,
Tank's fore the nice comments :) mounted the board.
PostPosted: Mon Feb 16, 2009 12:55 pm
Looks nice,
If you get a lot of hum, or overly distorted sounds, check out the first 2 Oil paper caps with the metal bodies, I had a problem with one Tweed I used & changing the caps to poly, made the difference.
Just be aware of it
PostPosted: Tue Feb 17, 2009 11:42 am
Wow, perfect work! Looks like you used a micrometer, setting all the parts and wires in accurate alignment. Do you alphabetize your food cans in the pantry, and stack your coins in order on the bedroom dresser? Just kidding... you're doing a superb job on that amp. I love my Deluxe, and think you'll have the most satisfying part of the experience when you can fire it up! Although with that great wiring and mounting job, you'll probably want to show it off to your friends...
Best,
Jim
PostPosted: Fri Feb 20, 2009 6:56 pm
Hi ,
Tanks for the kind words , did finish the amp to day and fired it up very quiet. Tested it fist whit a Jensen c12n speaker not very loud but it wasn’t mounted in a cab, then I tested whit a ac 15 combo whit a celestion blue. The amp sounded super loud and fine , got to thank Stephen for supplying me whit a very fine chassis and trafo set. No I have to mount a VVr and build a cabinet . Planning on mounting the VVr on the back off the chassis whit it a heat sink and the control pot . Btw this is my first scratch build the first amp I made was a sIII kit from Stephen .
PostPosted: Fri Feb 20, 2009 11:05 pm
Nice job. Looks awesome! What tubes did you use?
PostPosted: Fri Feb 20, 2009 11:26 pm
Beautiful job Malt 8)
BTW: Where did you find HOTweezers®?? I can't find them in the USA any more :?
PostPosted: Sat Mar 21, 2009 11:21 pm
Hi got some black plate 6v6 Hi-Ray tubes made in Japan wrestling house 5y3
sylvanya 12ax7 and a jan 12ay7.
Joe g I got the hot tweezers of ebay just bought to more tweezers for 28$
her are a base http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0356957015
Tweezers the b7 is the one you want for amp work http://cgi.ebay.com/MEISEI-CORP-HOT-TWE ... dZViewItem
PostPosted: Sun Mar 22, 2009 11:44 am
malt wrote:
wrestling house 5y3
:lol: :lol:
What is a HOTweezers®? Some kind of fine soldering tool??
PostPosted: Sun Mar 22, 2009 12:36 pm
Thanks for the info Malt. I've been using HOTweezers™ since the early 80's. They're not distributed in the USA any more, probably because they would never meet UL the way they're built :shock: I have a few sets but the handsets go after a while. The power supplies last forever, although the shut off/holding stands do break over time.
Phil... The HOTweezers™ are IMO the best thermal strippers out there, once you get a rhythm going with them. They can burn or melt a bit on PVC coated wire if you're not careful, but they are a must for Teflon® coated. Light weight handset, no nicks in the wire (when used correctly), they have a great length gauge for repeatable strip lengths, etc. They are fairly costly though!!
