It is currently Tue Mar 31, 2026 1:03 pm
PostPosted: Sun Dec 14, 2008 3:47 pm
Well, I finished up all my soldering/components installation yesterday, and fired up the amp for the first time today....no sound :? No hum, no buzz, no nothing.
Now, after a PM from Coco, I realized I installed the shielded cable incorrectly - would that contribute to my lack of sound?
Here are my voltages as well (recommended voltages in brackets). Any help from you experienced builders out there?
Voltages:
V1
Pin 1 - 133 (120)
Pin 3 - 2 (2)
Pin 6 - 136 (123)
Pin 8 - 2 (2)
V2
Pin 1 - 167 (167)
Pin 3 - 1.1 (1.1)
Pin 6 - 210 (175)
Pin 8 - 50 (70.5)
V3
Pin 3 - 377 (380)
Pin 4 - 349 (338)
Pin 8 - 22 (22)
V4
Pin 3 - 380 (382)
Pin 4 - 349 (339)
Pin 8 - 23 (22)
Any suggestions?
PostPosted: Sun Dec 14, 2008 4:47 pm
make sure the sheilded cable isnt shorting out by the tube socket I had that problem,
PostPosted: Sun Dec 14, 2008 5:56 pm
Thanks! I'll be fixing my error with the shielded cable, and will make sure it's not shorting out against the tube socket.
While probing around, I noticed something else sort of strange. I was checking the capacitors to see how much charge was left, and the first orange cap after the three black caps had no charge (every other capacitor had the same charge remaining...14 volts or so left). Could this have something to do with my strange voltages on the pins of V2?
PostPosted: Sun Dec 14, 2008 8:20 pm
Your voltages are good - close enough for tubes amps with carbon comp resistors!!
Make ure you've got the jacks wired correctly and that piece of co-ax too.
PostPosted: Mon Dec 15, 2008 7:12 pm
Still no sound... :? I fixed my problem with the coax (and found another problem with the way I did it originally). Checked the build...couldn't find any other inconsistences...but I am starting to go a little screwy from staring at the board!!!
No sound at all...with the voltages being correct (as you pointed out earlier, coco) - where else should I be looking? Is this essentially a problem between the input or output jacks and the board?
PostPosted: Mon Dec 15, 2008 7:30 pm
Nevermind! It works :shock:
After I fixed my coax issues, I forgot to reinstall a tube I pulled....
Thanks so much for your help...off to play!!!!! :D
PostPosted: Mon Dec 15, 2008 9:37 pm
Congrats! No sweat. It's happened to all of us. Enjoy!!
