It is currently Tue Mar 31, 2026 1:16 pm
PostPosted: Mon Nov 23, 2009 10:06 am
Hi,
I've just started this build. (Heaters, pilot lamp are wired, and some ground connections are made.)
I would like to ask how many of you made the optional V1 input as mentioned in the manual. You know, terminal strip with resistors at the base of V1, shielded cable to there from the inputs...
And, since I will be placing a switched pot in the position of the on/off switch, I'm looking for a way to center the pot in the hole. The hole for the switch is a little bit bigger than pot diameter. Any ideas ?
Thanks !
PostPosted: Mon Nov 23, 2009 10:39 am
Take a look here...
viewtopic.php?t=1567
Scroll down and you should find a similar issue they have with the Triwatt switched pot :)
Joe G
Some assembly required,
Brain sold separately...
