It is currently Tue Mar 31, 2026 1:15 pm
 Post subject: 5e3
PostPosted: Mon Mar 29, 2010 9:54 pm
just finished my build, the amp starts up great, at low volume "around 2 and under the amp sounds great, but when I turn the amp past 3 it starts to cut out on me and the sound comes and goes??? any clues I have checked the solders and everything seems well, could this be a problem with one of the tubes???
PostPosted: Fri Apr 02, 2010 7:31 pm
Any luck on this. It's a new one to me. I would have thought a solder joint or I guess it could be a tube.
PostPosted: Fri Apr 02, 2010 8:17 pm
Ive had a similar thing happen but in pedal. Turned out to be a poor connection on a volume pot, was causing an intermittent connection.
PostPosted: Mon Apr 05, 2010 8:52 am
I'll pull apart the pot and give it a shot thanks
