It is currently Tue Mar 31, 2026 2:16 pm
PostPosted: Mon Nov 22, 2010 10:33 am
Because of limited space in a donor chassis, I need to use one volume, one tone, and a switched brite rather that 4 inputs. Does anyone have a layout for this?
Jon
PostPosted: Mon Nov 22, 2010 1:40 pm
You could. But if you did a strict copy you'd be left with a triode doing nothing. If you wanted to make a one channel 5E3 you have three triode sections and the 5e3 has two. I'm working on doing a one channel 5e3 but with a tweed bassman preamp. That way I'm using all three triode sections (two for the preamp and one for a cathode follower)
I'm still debugging it though :damntech: :roll: :wink:
