It is currently Tue Mar 31, 2026 4:21 pm
PostPosted: Sun May 22, 2011 4:32 am
PostPosted: Mon May 23, 2011 12:14 am
PostPosted: Tue May 24, 2011 10:40 pm
PostPosted: Wed May 25, 2011 11:12 pm
These have been kurtlives steps in troubleshooting the VRM...
If the VRM is doing nothing it's good to check the Zener diode out. Use a continuity tester and see if it conducts. If it does conduct it's bad.
If the VRM wont pass voltage check the 5W 100R resistor. You can measure it in the circuit to see if it reads correctly or it has opened up.
Other than triple checking all your wiring, jumpers and component values then I'd suspect the MOSFET.
PostPosted: Sun May 29, 2011 10:27 pm
