It is currently Wed Jul 02, 2025 7:08 am
PostPosted: Thu Apr 07, 2016 10:56 am
In the process of putting together a cabinet, I've been trying to avoid screws in favor of bolts and t-nuts. I was wondering, is there a downside to attaching the baffle to the cabinet fascia using bolts from the outside to t-nuts on the inner side of the baffle rather than screws?
I'm already using t-nuts for the speaker, and intending to using them for the handle, potentially the back plates.
http://amparchives.com
PostPosted: Fri Apr 08, 2016 3:21 pm
No Down side. We use them for the handles too.
You may not have enough space to fit them inside the cabinet.
PostPosted: Sat Apr 09, 2016 12:27 pm
No downside really except not really needed there. Handles and the speaker they are a must.
If you really want to use them to fasten the baffle, I'd install the t-nuts to the battens before you install them to the cabinet body. Would make it a lot easier.
PostPosted: Sat Apr 09, 2016 1:46 pm
On a tweed, they would be pretty close to the edge. Besides, nuts and bolts are easy to install!
