It is currently Thu Dec 04, 2025 3:21 am
PostPosted: Thu Jan 12, 2012 9:07 pm
How do you attach the tube sockets to the chassis? I would suspect that there are nuts, but that doesn't look to be the case
PostPosted: Thu Jan 12, 2012 9:53 pm
The chassis is tapped, meaning the chassis is basically the nut. The chassis is threaded.
You should just need #4 bolts 5/8".
This is probably outlined in the kit instructions.
