It is currently Sat Jun 13, 2026 12:16 am
PostPosted: Mon Mar 26, 2012 9:24 am
I'm not a wiz when it comes to electronics but have been successful in building about 30 "Champ" kits and a few Marshall clones, a Brown Note and pedals. I'm finishing a Deluxe build and it sounds great. I am having difficulty as to which wires to connect to the B+ IN and OUT. More specifically - which wire from the standby switch and which wire from which filter cap? The instructions are a bit confusing (at least to a beginner like me). Thanks for your help.
Denny
PostPosted: Sun Apr 08, 2012 11:36 pm
the wire on the "output" side of the standby switch that goes to the board. Reomve it from the switch, move it to the OUT terminal on the VRM board and then put new wire from the standby switch to the VRM IN terminal.
PostPosted: Mon Apr 09, 2012 8:12 am
Thank you VERY Much!!
Denny
