Thanks for the reply, I went through again and found a short and fix, and redo some wirings then check voltages again. Following readings now with no rectifier V5-pin 4&6-733v,pin 4 and 6 to ground both 364v, across pin 2&8-5.2 V4 and V3 across pin2&8 both 6.5 V2 and V1 across pin 4/5 and 9 both read 6.5
With rectifier tube B+ 376vdc With all the tubes inserted,speaker plugged V1- pin1-104, pin3-1.5, pin6- 96, pin8- 1.5 V2-pin1-132, pin3-0.9, pin6-155, pin7-8, pin8-29 V3- pin3-353, pin4-263, pin8-28 V4- pin3-337, pin4-263, pin8-28
After the voltage check, plugged guitar there is output coming out of speaker, increase volume but volume the same to the max just the distortion is changing. Volume is not there. What I noticed was there was a smoke coming from the connection of output to the board, the resistor start smoking, check connection ok and notice it has different colour code suppose to be yellow-violet-red, what I have is yellow-violet-brown. I remove the resistor and measure the resistance 4.63k ohm. Is that the right value for 4k7 2W and the right resistor for that circuit? NOTE :The bottom pic is the location of the resistor that I remove, I just place the part and not soldered
| Attachments: |
